Indicates failure in port configuration.This might be because of enabling link fault management on copper/combo ports or half duplex ports or on ports with auto negotiation off
Check whether the port is full duplex ports with auto negotiation off and has support for link fault management.
Error
%portCfgFailDetail% %port%
| Name | Type |
| portCfgFailDetail | String |
| port | String |
